Adobe Flash Security
alanf
Worries about the vulnerability of Adobe Flash seem to be on the rise. There is just been the third security update in a week to fix known flaws and the expectation of others to come.
https://krebsonsecurity.com/2015/07/third-hacking-team-flash-zero-day-found/
10 REPLIES 10
rongtw
Fixes: 12
Re: Adobe Flash Security
just seen this Firefox is to start blocking flash http://hexus.net/tech/news/software/84659-mozilla-firefox-browser-starts-block-flash-default/
Steve
Seasoned Pro
Would this affect Chromium and Pepperflash?
If life gives you lemons, make lemonade.
sjptd
The vulnerabilities apply to all browsers.  Whether Flash is allowed by default will vary between browsers, and different versions of the same browser.
There are useful plugins like Flashblock for Chrome.  Often used more to reduce the irritating effects that Flash is often used for.
shutter
Fixes: 64
OK.. I have been getting messages at the top of the screen about Adobe Flash being blocked... and have to click something to make it work...
If it is "so bad" that firefox has to block it.... what alternatives are available that do the same job ?
Steve
Seasoned Pro
@shutter I have been getting them too and it's annoying to be honest. I use Google Chromium with pepper flash ( I'm using Linux desktop ) might be a possibility for windows? As far as I know pepper flash is not Adobe flash but built by Google so I think I answered my own question in my previous post. And to be honest Chromium is much faster than Firefox I might just be converted lol.
Other than that how has HTML5 progressed?
shutter
Fixes: 64
OK... Dont know about HTML5... could be a hi speed train for all I know ! ! !...  Cheesy
Strat
Fixes: 565
I've seen online videos that pop up a message "I see you don't have Adobe Flash Player. Would you like to watch an HTML5 version instead?"
Kremmen
Fixes: 5
I have uninstalled the Flash ActiveX, the NPAPI (whatever that was) and Adobe Air.
Enough is enough with this vulnerable addon/plugin
Let's be careful out there !
rongtw
Fixes: 12
apparently they have released a update  Wink
http://blogs.adobe.com/conversations/2015/07/resolution-for-recent-flash-player-vulnerabilities.html
Steve
Seasoned Pro
Quote from: Strat
Yes you tube does HTML5  https://www.youtube.com/html5?gl=GB
