Adobe Flash Security
- Adobe Flash Security
14-07-2015 5:03 PM
https://krebsonsecurity.com/2015/07/third-hacking-team-flash-zero-day-found/
Re: Adobe Flash Security
14-07-2015 5:57 PM
14-07-2015 6:03 PM
14-07-2015 6:09 PM
There are useful plugins like Flashblock for Chrome. Often used more to reduce the irritating effects that Flash is often used for.
15-07-2015 8:39 PM
If it is "so bad" that firefox has to block it.... what alternatives are available that do the same job ?
15-07-2015 9:10 PM
Other than that how has HTML5 progressed?
15-07-2015 10:17 PM
15-07-2015 10:42 PM
16-07-2015 5:37 AM
Enough is enough with this vulnerable addon/plugin
16-07-2015 6:12 AM
http://blogs.adobe.com/conversations/2015/07/resolution-for-recent-flash-player-vulnerabilities.html
16-07-2015 5:28 PM
Yes you tube does HTML5 https://www.youtube.com/html5?gl=GB
Quote from: Strat I've seen online videos that pop up a message "I see you don't have Adobe Flash Player. Would you like to watch an HTML5 version instead?"
