Adobe Flash Player Download... Now. . . sorted !....
- Adobe Flash Player Download... Now. . . sorted !....
15-11-2013 10:39 PM
I get the "install now" page... and then I click on that , and the next page that shows up is advertising more adobe products... just can`t see it downloading, or anywhere to click on to get the download.
Help please.
EDIT EDIT EDIT
I expected it to be downloaded under A for Adobe..... or F ... for .... Flash Player... so did not look further than that as " i " was not visible on the screen....until I scrolled for something else.
Well, I thought it was sorted.... but it seems that was for an older version... now I just go round in circles,as originally posted....
PLEASE... someone... tell me how to get the latest version of Flash Player Downloaded... or Update the version I now have....
Re: Adobe Flash Player Download... help please NOT sorted !....
15-11-2013 11:15 PM
On clicking Install now what downloads is a 1MB installation management file. The much larger Flash Player file downloads and installs when the management file is run. Some questions had to be answered (no doubt offers declined - can't remember) along the way.
Running that file updated my previous installation.
15-11-2013 11:24 PM
When I click on the yellow box, bottom right [Install now] I am then presented with the second page...
there is nowhere on that page to proceed further... ( except if you find "downloads" and click on Flashplayer... I get the first page again )
16-11-2013 12:35 AM
When I did this live I saved the file, then double-clicked it to run it. When installation completed I think a separate "Thank You" window opened, can't remember what it showed, I closed it after a quick glance. The previous window was still Step 2 of 3; I closed it (didn't get to see Step 3 of 3).
Edit: After updating Flash Player on Internet Explorer I discovered the Thank You page is, in fact, Step 3 of 3.
16-11-2013 8:55 AM
However.... !
I thought it might be something to do with FF, so I dug up the Internet Explorer short cut, and eventually managed to get it downloaded properly ( same routine as you) through that, somehow... !..
What a lot of Pfaffing about.. !... why they have to use a "downloader" to download their stuff. and make it so difficult compared to a simple "download now" button is beyond me....
Thanks for your input... ( was very early this morning when I finished )... !
Re: Adobe Flash Player Download... Now. . . sorted !....
16-11-2013 7:05 PM
Perhaps clutching at straws but I think the offer panel content might be JavaScript driven - ticking/unticking the box toggles a T & C entry on the right. Do you allow JavaScript to run in Firefox?
16-11-2013 7:23 PM
never had any problems with other sites... and downloading. etc... click and it works !...
16-11-2013 9:21 PM
Incidentally, you always post screenshots with photographs. Don't you know how to 'print screen'? It provides a much clearer picture of what's going on.
16-11-2013 9:25 PM
Don`t really understand all this java script and stuff, working in the background... I may have it switched off, but again, wouldn`t know, nor how to,/wher to go, to switch it on... !
My yoututbe vids work, ok now... and I`ll scream and shout if something else doesn`t work !..
cheers
16-11-2013 10:18 PM
16-11-2013 11:48 PM
thanks for the advice..
( ps... I know about customise ! ! )..
cheers
17-11-2013 3:26 AM
I think there is one particular Adobe tracker that you need to 'enable' as it breaks a lot of sites from functioning, I forget which one it is ATM but I'll update when I next look in.
18-11-2013 3:25 PM
You need to enable 'Omniture (Adobe Analytics)' then reload the page (you'll need to enable the green tick to always allow it), after which the option to download McAfee is present, and the 'Install Now' button will download he appropriate file.
For me, it's updated Flash to 11.9.900.152
18-11-2013 5:47 PM
