Adobe Acrobat 6
Adobe Acrobat 6
Hi all, i am using Adobe Acrobat 6 and whenever i right click a word document and 'Convert to Adobe PDF', the pc seems to be doing something then stops, i have no idea if it converted the file or where it went. I have seach the entire C:\ but no file.
Does the same when tring to combine files in Adobe PDF?
Any idead!
Re: Adobe Acrobat 6
In my experience, usually, once the document has been converted, Adobe will automatically load the file so you can preview it and select a save location. Sounds like Adobe is crashing halfway through the process, you might find the file in your TEMP folder, but I would try reinstalling Adobe Acrobat, or upgrading to the latest Acrobat Professional version.
