Address forwarding
- Address forwarding
Address forwarding
24-08-2009 10:08 AM
Hi folks,
I have a PlusNet account with several domains under it, but what I'd like to do is have one of my domain names forward to a subsite under another domain i.e. navigate to www.abc.com actually takes you to www.xyz.com/abc. Does anyone who if anhow this can be done?
Thanks for your help
Kevin
Kevin
2 REPLIES 2
Re: Address forwarding
24-08-2009 10:30 AM
Yup, this can be acomplished using a variant on the instructions in http://community.plus.net/forum/index.php/topic,78811.0.html
I can't guarantee the code below will work, but a .htaccess file with something like
may do the trick.
Quote Options +FollowSymLinks
RewriteEngine On
RewriteCond %{HTTP_HOST} ^www\.abc\.com$
RewriteRule (.*) http://www.xyz.com/abc//$1 [R=301,L]
may do the trick.
27-08-2009 10:47 AM
As per the other conversation, if I take out the Options +FollowSymLinks it works fine, otherwise I get an internal server error.
Kev
Kev
