Adding static routes to 2704n... Or enable ssh??
dlm2000
Interested
Hi
I was just wondering if anyone knows how to add static routes to the plus net 2704n.  Ideally without replacing the firmware.
An alternative would be to enable telnet/ssh.
Anyone know if away of doing this?
dlm
2 REPLIES 2
core2lee
Re: Adding static routes to 2704n... Or enable ssh??
I know for certain the Telnet/SSH functionality is disabled and by design cannot be re-enabled in the Plusnet firmware. Not really had too many dealings with the 2704n but I know there are some extra config options if you go to 192.168.1.254/expert_user.html
Anotherone
Champion
Fixes: 21
See also this thread on this board. There are a few other helpful threads around. I'll try and find a few links. Note that the firmware v2 does not allow the config to be downloaded in text format Crazy3
