Adding radio stations to windows media player
- Adding radio stations to windows media player
23-12-2008 2:46 PM
Hi guys not sure if this can be done but sure i have done it before, just wondered if its possible to add radio stations of my choice to windows media player 11, thanks in advance.
1 REPLY 1
Re: Adding radio stations to windows media player
23-12-2008 11:03 PM
Yes select the media guide then radio then on the right radio tuner it gives you the option of some radio stations or search for some in certain categories or add them if you know the url
