Add/remove in Vista.
In Vista where is the add/remove facility?  Trying to install a new programme from a CD.
Fixes: 20
Re: Add/remove in Vista.
Control panel >Programs and Features  (some bright spark decided it needed to be renamed,.... to modernise it ! ! )  Roll eyes
Thanks Shutter.  That seems to uninstall without a problem.  What about installing?
Fixes: 62
auto run from the CD or if it doesn't do that double click on the exe file on the CD
Thanks Oldjim.  Between you and Shutter my problem is solved. Smiley Smiley
Fixes: 62
Us oldies have some use
You sure do Cool Cool
