Ad blockers
- Ad blockers
Ad blockers
23-05-2017 6:47 PM
is it just me or are more and more web pages blocking the ad block add on,s ?
my local paper http://www.thetelegraphandargus.co.uk/ wont even let you view photos if adblock running
1 REPLY 1
Re: Ad blockers
23-05-2017 6:56 PM
Yep more and more, they would think they would take the HINT, WE DON'T WANT MASSIVE/LOADS OF AD'S.
If they block it then I just block them, simple really.
