Ad-Aware V 8.1.0 2010
- Ad-Aware V 8.1.0 2010
02-11-2009 4:00 PM
For all who use the free addition of Ad-Aware, are you aware there is a problem with the upgrade from previous editions? The scan stalls a certain point & everything locks up. You can read all about it here http://www.lavasoftsupport.com/index.php?showforum=176
If you want to download an earlier version you can get it here: www.filehippo.com
5 REPLIES 5
Re: Ad-Aware V 8.1.0 2010
03-11-2009 10:42 AM
I use Ad Aware but haven't come across this problem. The latest version that I am using is 8.1.1 though.
03-11-2009 10:54 AM
Hi there, I'm wondering if it could be an issue with XP as I have been unable to use the new version on my desktop but my daughter's laptop is running Vista & hers is working ok.
At present I've gone back to the Anniversary edition as it works fine for me, I just hope Lavasoft continue to support it until the creases are ironed out of the new version!
03-11-2009 11:33 AM
I'm using version 8.1.0 on XP with no problem.
04-11-2009 7:59 PM
if ad-aware causes a few problems just switch to something else -- that's what I did long ago -- it only ever found cookies anyway
I use superantispyware now on my XP -- never had a glitch or stall when running the program
04-11-2009 8:34 PM
Same as barky here.... use superantispyware... no problems.... also use CCleaner .... they work well together.
