Actionfraud is not loading F/Fox 26.0 has it moved
- Actionfraud is not loading F/Fox 26.0 has it moved
18-01-2014 9:11 PM
OpenDNS reports
You tried to visit www.actionfraud.org.uk, which is not loading.
Is it the same for you ?
isitdown.co.uk reports
http://www.actionfraud.org.uk is down
(it took me 0.37 seconds before I gave up, if it is your website contact your web host now)
More help: Google cached version ( no images ) Let the web master (whois) know
BTW: The status code I got was 404
Has it moved or changed URL
Even more strange actionfraud.org returns to
screenshot software
screenshot software
2 REPLIES 2
Re: Actionfraud is not loading F/Fox 26.0 has it moved
18-01-2014 10:01 PM
18-01-2014 10:14 PM
Thank you beeceegee
That works
However I would of thought that since it is now clearly an obvious change of address, they would of implemented a Re-Direct from the old address.
That works
