Acess Denied
- Acess Denied
Acess Denied
01-09-2017 9:27 AM
Yesterday and so far today, when trying to access ebay and sony psn I get access denied in browser, A lot of other sites like facebook and twitter seem to be OK . can anyone shed any light on what could be causing this. I did a trial of booster called fast. But uninstalled it. Could that have changed something ?
Re: Acess Denied
01-09-2017 9:38 AM
If its confined to the one device you installed this odd software, I can't be 100% sure as I can't find this speed booster application - it sounds like malware to me - but it's possible that it may have modified your host file to reroute your internet for specific websites? This is a pure guess as it has happened to me in the past. You need to take a look at your hosts file and make sure that it doesn't have anything in there that is blocking access to certain urls.
1. Press the Windows key.
2. Type Notepad in the search field.
3. In the search results, right-click Notepad and select Run as administrator.
4. From Notepad, open the following file: c:\Windows\System32\Drivers\etc\hosts.
5. Make the necessary changes to the file.
6. Click File > Save to save your changes.
If that didn't work and you are certain that this is isolated on that one device, if its windows you may be able to restore the operating system to a time before you installed that app via the windows backup.
Hope this helps!
Re: Acess Denied
01-09-2017 9:40 AM
Re: Acess Denied
01-09-2017 9:44 AM - edited 01-09-2017 9:45 AM
Hi thanks guys
all browers chrome, FFox IE
1st thing I did was run malwarebytes found 3 files deleted
2nd did system restore to 10 days ago
3rd nothing in the hosts file
except "#
# This is a sample HOSTS file used by Microsoft TCP/IP for Windows.
# This file contains the mappi Each
# entry should be kept on an individual line. The IP address should
# be placed in the first column followed by the corresponding host name.
# The IP address and the host name should be separated by at least one
# space.
# Additionally, comments (such as these) may be inserted on individual
# lines or following the machine name denoted by a '#' symbol.
# For example:
# localhost name resolution is handled within DNS itself.
Re: Acess Denied
01-09-2017 9:49 AM
Do you have the same issue with other devices? Say... a smart phone, tablet, laptop, games console, second computer that can connect to the router? If the problem persists on those devices, it could be an issue with your connection.
Re: Acess Denied
01-09-2017 9:56 AM - edited 01-09-2017 9:59 AM
Yes just tried my android phone and cannot access e-bay on that . and on my android tablet . both access denied
would rouer/modem factory reset help sort it ?
Re: Acess Denied
01-09-2017 10:05 AM
Ah, so this could be a problem with your connection and not something isolated on a single device so we can assume that this is an issue with the router/connection.
You could check your router settings before doing a factory reset... log in to the router via your browser and check the settings. It's possible that your username and password might not be right? If you know your plusnet username and password, just reenter them into the router settings to be sure.
@Gandalf, are you able to see if you can pinpoint the problem from our side at all? I don't have access to anything like that myself so I am making guesses in the hope that we can figure this one out between us. Might need your expertise if you can lend a hand
Re: Acess Denied
on
01-09-2017
10:14 AM
- last edited on
01-09-2017
10:28 AM
by
jaread83
From what I can everything looks fine in the router settings, if it wasn't would I be able to connect to here or some other sites ? two little things I noticed there is no listing for other devices connected to the router and the ip address looks odd to me never noticed it before <ip address removed>
Re: Acess Denied
01-09-2017 10:30 AM
That's your public facing IP address - I have removed it from here as you don't want that to be out in public Hopefully one of our support staff will be able to take a look in the system for you as I am now out of ideas from what I would personally do if it were me (I'm not support staff so I can't access anything in the system specifically for your connection).
Re: Acess Denied
01-09-2017 10:33 AM
whoops forgot that about displaying ip. thanks. I really appreciate your help and advice . I'll open a ticket with support and see what they come up with ..
once again many thanks .
Re: Acess Denied
01-09-2017 10:37 AM
Re: Acess Denied
01-09-2017 10:41 AM
Frustrating isn't the word. especially when trying to set the PSN up on the PS3 so kids can play and watch youtube on it. I forgot that the PS3 throws up an error to so clearly points to connection. the ebay denied is OK stops us spending what we don't have lolol
Re: Acess Denied
01-09-2017 10:45 AM
Re: Acess Denied
01-09-2017 10:49 AM
don't use that one . have one on router and one on PC which are ok .. seemed over kill to have anymore ...appreciate the thought
Re: Acess Denied
01-09-2017 10:52 AM
