Access to this site is blocked
Oldjim
Resting Legend
Fixes: 63
http://www.climateaudit.org/
I have no problem getting to this site from Firefox but from IE8 I get this - does anyone else see this
Clicking on the solve it yourself link I get this
Technical Support
Your request was intercepted by Bad Behavior, security software which protects the Web site you visited from malicious activity, such as hackers, spam and viruses. We apologize for the inconvenience, but your request matched a profile of suspicious activity. This problem is usually quite easy to fix.
You accessed the Web site using software which is banned due to malicious activity associated with that software. Uninstall it from your computer and contact the software's author for assistance. In the meantime, you may access the site using different software, such as Firefox.
This problem may be caused by misconfigured or malfunctioning browser privacy software or personal firewall software. If you use this type of software, turn it off or reconfigure it and try again.
8 REPLIES 8
Fixes: 1,483
Re: Access to this site is blocked
No problem for me OJ, working in IE8 and FF3.
Oldjim
Resting Legend
Fixes: 63
Just checked with IE8 on Windows 7 and it works - must be something to do with Kaspersky as Windows 7 uses Avira
Must do some checking
Alex
Fixes: 13
I'm using IE7 on Vista and it works.
I have Kaspersky .. but I have the content filtering switched off.
(Can't remember why I did it, I think it was interfering with my e-mails in a way which was annoying me).
Alex
Fixes: 13
Hmm .. enabled content filtering and it still seems to work.
Oldjim
Resting Legend
Fixes: 63
Most odd - I have dropped an email to the software developers - let's see what happens
scootie
works fine on ie8 here.
ive been having few random problems with bbc iplayer site menus since installing SP2  the streams are fine but the webpages just dont play ball some times
are using inprivate filtering on ie8?
Oldjim
Resting Legend
Fixes: 63
No - I like to keep my history etc
scootie
nah inprivate filtering is diffrent its the next option down from private browsing in the tools menu.
dosent matter now i tried it turned on and i still have no problems with the site.
