About RouterStats and Windows Control Panel Add Remove
Luzern
Seasoned Pro
Windows XP Netgear DG834G v3
I downloaded the zip file and extracted it to a folder in Program Files, but even though it works, it appears neither in the Add Remove Programs lost nor is it to be found in the Registry.
I do not understand, so can  any one advise me why the problem exists and how I correct it? Please!
Fixes: 62
Re: About RouterStats and Windows Control Panel Add Remove
That is because you don't install it. It just runs from the folder
Fixes: 10
If you do decide to uninstall it all you have to do is delete the directory.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
