About RouterStats and Windows Control Panel Add Remove
- About RouterStats and Windows Control Panel Add Re...
12-01-2010 9:13 PM
Windows XP Netgear DG834G v3
I downloaded the zip file and extracted it to a folder in Program Files, but even though it works, it appears neither in the Add Remove Programs lost nor is it to be found in the Registry.
I do not understand, so can any one advise me why the problem exists and how I correct it? Please!
2 REPLIES 2
Re: About RouterStats and Windows Control Panel Add Remove
12-01-2010 9:27 PM
That is because you don't install it. It just runs from the folder
12-01-2010 9:56 PM
If you do decide to uninstall it all you have to do is delete the directory.
