Abobe camera raw
- Abobe camera raw
Abobe camera raw
13-11-2009 7:02 PM
Any one know what the last camera raw version was for CS3 ?
3 REPLIES 3
Re: Abobe camera raw
13-11-2009 7:06 PM
ok it's 4.6 but cant find a download for it everything points to the adobe site but then loads the 5.5 which is for cs4 only
edit got there in the end http://www.adobe.com/support/downloads/thankyou.jsp?ftpID=4034&fileID=3758
13-11-2009 7:16 PM
google suggest 4.1
Quote #
Adobe - Photoshop : For Windows
Adobe DNG Converter and Camera Raw 4.1 update, 5.9MB, 5/30/2007. Version CS3 - International. Adobe® Photoshop® 10.0.1-oppdatering for Adobe Photoshop CS3 ...
www.adobe.com/support/downloads/product.jsp?platform...39 - Cached
Adobe - Adobe Photoshop CS4: Digital camera raw file support
Camera Raw 5 and later is not compatible with Photoshop CS3. ... capture DNG format raw files and thus are compatible with Camera Raw version 2.4 and later. ...
www.adobe.com/products/photoshop/cameraraw.html - Cached - Similar
Show more results from www.adobe.com
Adjusting Exposure in Adobe Camera Raw CS3 - Photoshop CS3 ...
Article on adjusting exposure in Adobe Camera Raw CS3, by Photoshop expert and author ... The standard version of Photoshop CS3 is available for US $649, ...
www.photoshopsupport.com/...cs3/...camera-raw.../index.html - Cached - Similar
13-11-2009 7:20 PM
i found and got it working now pierre http://www.adobe.com/support/downloads/thankyou.jsp?ftpID=4034&fileID=3758
needed it for my pentax K100 PEF's but i havent checked it works with my K20D yet thoe
