AVI files
- AVI files
AVI files
09-01-2011 4:45 PM
Re: AVI files
09-01-2011 5:02 PM
A note of caution, unless you have a recent, multi-core processor, video conversion can take a long, long, long time.
Re: AVI files
09-01-2011 5:10 PM
Re: AVI files
09-01-2011 5:31 PM
best bet though is dvd burning software, set to burn as dvd video
Re: AVI files
09-01-2011 6:28 PM
Re: AVI files
10-01-2011 12:17 PM
Re: AVI files
10-01-2011 4:35 PM
A newer DVD player that plays Divx etc
A Media player - from about £20 if you want SD £40 for HD with HDMI etc.
A console like an Xbox (old one with XBMC on it - used one for years as my standard media center until I wanted HD content)
Re: AVI files
10-01-2011 6:08 PM
The previous DVD player was O.K. with DVD's produced with DeVeDe on the PC.
I suspect it's a DRM (Digital Rights Management) problem.
Re: AVI files
11-01-2011 3:32 PM
Quote from: pierre_pierre if you get the new copy of PC Utilities Magazine Issue 135, just come out, it has all the programs you need on its DVD to do what you require, cost £5.99
Thanks I will get a copy of that.
Quote from: pierre_pierre must be an old DVD player, most new ones play different formats
Well not that old, it's a Sony DVP - NS78H.....with a software conversion to make it an all regional player.
I guess what I was looking for may not exist, I assumed there might be some hardware whereby you connect something to the television / computer and it would transmit via a wireless connection anything playing on the computer to the television.
You can possibly tell from this statement that my knowledge of this topic is zero but thought it worth checking out.
No doubt I will end up having a bash at converting the files but as johpal says it takes a long, long, time
Re: AVI files
11-01-2011 3:45 PM
http://handbrake.fr/
Re: AVI files
11-01-2011 4:57 PM
Re: AVI files
12-01-2011 12:40 PM
Thanks for that link, looks intersting, i'm always looking for free (or cheap) programs.
Quote from: Matt If you do, take a look at Handbrake - not that I convert much video, but that's a free program with some good tutorials online and (iirc) a relatively simple interface... for a video transcoding program, anyway.
Johpal,
Quite interesting reply, unfortunately my TV is fairly new so a change of telly is not an option for me
Re: AVI files
12-01-2011 1:08 PM
Thanks for that, solved a problem for me. The files saved by my Hauppauge Freeview card with the latest version of WinTV can now be converted to a "useable" format. Earlier versions of WinTV created pretty standard MPEG's but not this one.
