AVG versus Avast
- AVG versus Avast
AVG versus Avast
26-08-2008 5:39 PM
Many people on this and other forums seem to prefer Avast so I have installed it on one of our computers and I have now got to grips with it, have it configured and it seems fine.
However, I have to confess that I don't know the fine (performance) details of each one and which is actually the safest or best. The only things that I am aware of is that Avast has rootkit protection (AFAIK) but AVG8 has spyware protection.
Could someone explain please so that I can understand a bit better?
Re: AVG versus Avast
28-08-2008 2:20 PM
Speaking as an AVG reseller you'd expect me to prefer AVG, but in fact Avast is proving to be much better in terms of protection level, is less obtrusive and much less of a resource hog.
Save your money, go for Avast Free Home Edition - I've not found a better one.
28-08-2008 5:36 PM
Although subjective, it did seem that Avast was less resource-hungry than AVG so this concurs with your findings.
Having already got spyware protection on the computer, the rootkit part of Avast is probably of more use to me so I think that I will go ahead and install it on my own computer.
29-08-2008 5:10 PM
29-08-2008 6:00 PM
Thank you.
29-08-2008 6:14 PM
29-08-2008 6:32 PM
29-08-2008 6:51 PM
30-08-2008 7:19 AM
30-08-2008 7:21 AM
http://www.avast.com/eng/download-avast-home.html
Let us know what you think of it.
30-08-2008 10:18 AM
Installation is slightly different from AVG because you have to register to receive the registration number via e-mail. You just copy and paste it into the box and that's it.
I found Avast to be a bit confusing at first but am more comfortable with it now that I have installed it on 3 machines.
The e-mail scanning is automatic and no set up is required. However, it doesn't automatically text certify clean mail unless you make a slight adjustment in the settings.
One other thing is that the help files don't appear to be in the programme interface but are accessed via Start/All Programmes/Avast/Help Files.
As artmo says, it would be interesting to know what you think of it.
31-08-2008 9:32 AM
The latest problem is it just seems to get stuck when coming across the file 'YServer.txt'. Clciking Cancel has no response and the only way to stop the scan is via the Task Manager. Deleting that file and restarting the scan is OK but then 'YServer.txt' get's recreated when Yahoo Messenger is run and the problem recurs.
I think I may give Avast another go. I did have it on a machine some time agao.
Forum Moderator and Customer
31-08-2008 11:48 AM
I've tried alot of Anti Virus Software.
None of them on their own catch everything.
Avast is pretty good on the whole,
I've advised it many times because I've found it particularly effective.
Avast also has a Packet Inspector,
if you're paranoid about Secuirty this has to be one of the best things I've seen yet.
It protects against known exploits, on ports Opened by Common Windows Services.
The kinds of things which wouldn't be thrown up by a Virus Scan,
because it's an Exploit in Existing Software.
Draw back of that is, it does make things slower.
I never have any Anti-Virus/Firewall running 24/7, there isn't really a need.
The thing I do like with Avast is that it will install a Contect Menu for Explorer,
so you can select files to be scanned as you wish.
I never was impressed by AVG what with some of its false positive identifications,
it used to annoying some of my friends who used it and were die-hard fans.
I use Security Task Manager and PSTools collection a lot now.
The tools give you a far better insight as to what Modules within Applications are running,
and what operations are actually going on - which can help tracking anythign which isn't detected by Virus Scanners.
Hope that helps...
Jim,
31-08-2008 12:16 PM
01-09-2008 9:47 AM
Quote from: artmo Loombucket, can you explain what rootkit is?
http://en.wikipedia.org/wiki/Rootkit
Wikipedia explains it better than I.
