AVG todays update
- AVG todays update
- « Previous
- 1
- 2
- Next »
Re: AVG todays update
22-03-2008 5:46 AM
Thanks guy's for your help (and PJ for the edit) AVG updated normally yesterday evening. Will look into shutting off auto update etc.
22-03-2008 11:38 PM
AVG does funny things sometimes.
A while back when the AVG restart thread was around, Mine had updated and ever since it was crashing on every reboot - despite the fact everyone elses was fine!
Mine had wanted a restart and never came back to life - I had to uninstall and then reinstall the latest version.
AVG is just weird sometimes..
23-03-2008 6:53 AM
Whatever AVG's little foibles, it's streets ahead of Norton, and I say that as a former dedicated Norton user of a number of years.
23-03-2008 12:11 PM
Yeah I agree with the above.
I used both Norton and McCrashee. Both were ok at detecting virus's, but both were useless at removing them. You had to download a special tool, run it, manually modify the registry etc etc etc etc.
AVG doesn't beat about the bush. It just does whatever is needed automatically and gets rid of it. No restarting, no registry editing, no "Download our fix" nonsense. It just gets on with it and clears the infection.
Considering that, I can put up with its odd little quirks and reinstalls.
- « Previous
- 1
- 2
- Next »
