AVG todays update
- Re: AVG todays update
AVG todays update
21-03-2008 9:48 AM
21-03-2008 10:10 AM
Just looked at AVG Free on one of my PC's and it says it's up to date and has Virus Database version 269.21.8/1337 released 20/03/2008
21-03-2008 11:29 AM
21-03-2008 11:35 AM
21-03-2008 11:47 AM
Maybe an uninstall and reinstall is the answer.
21-03-2008 12:43 PM
Quote from: PJ Have you recently made any changes to a software firewall
No!
21-03-2008 1:01 PM
Quote from: HPsauce Which edition is that?
werid mine is database version 269.21.7/1336 released 20/03/2008
does this mean i have a defrent version of avg
program version 7.5.519
21-03-2008 1:06 PM
Quote from: scootie
Does it depend which operating system you are using? I am using XP and my version is 269.21.8/1337 released on 20/03/2008.
21-03-2008 1:07 PM
so no its not to do with the windows version your runing
21-03-2008 1:13 PM
21-03-2008 4:09 PM
Quote from: jnwright There is a thread at
Ah ha!, so I'm not the only one then, thanks jnwright.
Found that once this window is showing, it is singularly difficult to close, it does not respond to X or right click/close, On the third of the 3 computers here, the best I could do was minimise it, until going to "task manager" and closed it there, task manager noted it as a "running programme"
Edit: anyone know why this happened, my comments follow the "quote" not inside the "quote" but the whole thing has appeared in the quote box, and underlined, which I didn't apply.
[Moderator's note by Peter (PJ): Fixed quote tags]
21-03-2008 4:47 PM
21-03-2008 5:02 PM
If you edit your post you will see that your typing is before the close quote code
21-03-2008 9:31 PM
Are your systems running an automatic full scan when they boot?
I find that killing the scan and update, then kicking off the update manually myself, usually sorts it out.
After all it's free!
21-03-2008 9:58 PM
