AVAST system scan
shutter
Fixes: 65
AVAST system scan
As there is no "specific" Anti-Virus Software board, I am posting in here....
I have changed from AVG FREE to AVAST FREE... when I had AVG, it would run a full system scan "in the background" when I scheduled it ... the only notification (I think) was an icon in the lower tool bar...
Now I have AVAST it runs a Full System scan, but there is a rather large notification box, which covers the bottom right scroll bar.. If I click on the X the box disappears. BUT does the scan continue to run? or is it cancelled by clicking on the X ?
3 REPLIES 3
7up
Fixes: 17
Re: AVAST system scan
Check the task manager, look at the CPU usage when you close the box to see if it drops or stays at the same level. If it stays at the same its still scanning (also you'll see the process still running too).
198kHz
Fixes: 41
Yes, it's still running.
If you right click on the tray icon and open up the interface you'll see the progress bar.
Murphy was an optimist
Zen FTTC 40/10 + Digital Voice   FRITZ!Box 7530
BT technician (Retired)
shutter
Fixes: 65
OK. Thanks.  I hoped it would be !. Smiley
