ATM operators eye Linux as alternative to Windows XP
- ATM operators eye Linux as alternative to Windows ...
29-03-2014 3:59 PM
Is this a good or bad eyedear ?
I think it would be a wise move if done correctly
Re: ATM operators eye Linux as alternative to Windows XP
29-03-2014 4:35 PM
The sheer number of things that run Linux in the background and run for years with no updates ...
29-03-2014 4:52 PM
do you think Linux will corner that market more ?
Or will the bullies win as normal ?
29-03-2014 5:22 PM
29-03-2014 5:39 PM
I doubt the end user will see any saving(s) as a result
So the Gov is playing follow the
29-03-2014 6:02 PM
I'm not really sure what people expect to happen if everyone starts using Linux everywhere. Linux-related companies are only going to make money if people pay them, not just if everyone downloads Linux for free and demands other people make something work / make something better / help them with it for free.
Or perhaps ATM operators will use Linux the same way as Technicolor use Linux for their routers. As in Technicolor get to use Linux, but the Technicolor firmware almost entirely runs binary blobs of proprietary closed-source software anyway, and of course it's not possible to install your own custom firmware into a Technicolor router.
30-03-2014 11:08 AM
30-03-2014 11:54 AM
30-03-2014 1:12 PM
WRT the routers, they should have had updates, routers are on the net all the time, they need to updated.
02-04-2014 9:35 AM
02-04-2014 9:56 AM
Quote from: Thunderclap Linux Mint for ATMs?
Nah, more likely Ubuntu for ATM
02-04-2014 8:16 PM
