AIR apps for MAC LINUX and Windows
Fixes: 21
Have found a couple of links to more AIR apps.....
60 + useful Adobe AIR apps you should know about........
http://www.hongkiat.com/blog/60-useful-adobe-air-applications-you-should-know
and this one from a comment posted on the above site.....boast 271 (and counting) AIR apps....
http://www.windyapps.com/
Fixes: 21
Re: AIR apps for MAC LINUX and Windows
If it isn't on there add the iplayer crap on to the list. You can watch but if you want to d/l you need Air  Crazy
I still hate the bbc for closing down the get_iplayer app. It was a great free app that did everything I wanted to do, i.e. download radio but with them closing the RTMP to open codec's it is only useful now for radio @ streaming speed. I used to get full speed downloads.
VileReynard
All Star
Fixes: 11
get_iplayer is back Grin
Make a backup of your current get_iplayer and enter
./get_iplayer --update
This should now have a version number of 2.78
Alternatively, you can load the full thing from
ftp://ftp.infradead.org/pub/get_iplayer/get_iplayer-2.78.tar.gz
(Ignore the windows sub-directory etc).
It even works with HD programmes for me. Grin
Fixes: 21
[Censored] was my post censored? It is what they call the page!  Crazy
So I cant even say W H Y ?
pierre_pierre
Found I had Adobe AIR on one of my Win XP laptops, so looked it up, seems you only need it if you write programs - is this another Adobe waste of space?
VileReynard
All Star
Fixes: 11
Don't know what it does, but
On January 28, 2009, Adobe claimed that there were over 100 million installations of Adobe AIR worldwide, and that "the majority of AIR runtime installations occur at the time the first AIR application is installed by a user."
[3]  The large number of installations is actually due to the fact that Adobe AIR was included with all downloaded installations of Adobe Reader 9 (released in July, 200Cool, with no option for exclusion either in the download or in the installation.
[4]  As of February, 2010, Adobe still bundles Adobe AIR (along with the application Acrobat.com) with the Adobe Reader 9.3 download, with no option for exclusion, and the installation file for Adobe Reader 9.3 still installs Adobe AIR without user permission.
(See Wikipedia)
pierre_pierre
from Adobe
The Adobe® AIR® runtime enables developers to use HTML, JavaScript, Adobe Flash® software, and ActionScript® to build mobile and desktop web applications that run as standalone client applications without the constraints of a browser. Adobe AIR and the Adobe Flash Platform unleash the creativity of designers and developers by providing a consistent and flexible development environment for the delivery of applications across devices and platforms. Support for additional platforms, including Android, is under development.
VileReynard
All Star
Fixes: 11
Sounds like a big security hole to me.
pierre_pierre
well that is typical of Adobe, I have a security program  Secunia that checks for holes, Adobe get more warnings than M$S
Fixes: 21
Thats why I said I will NOT install Air on my Linux boxes, so no iplayer off-line (without get_iplayer) as they require you to use Air to get any proggies.
pierre_pierre
is that because you have to compile them after downloading?, cant you just download and run in Linux?
Fixes: 21
Sorry no BBC Iplayer
VileReynard
All Star
Fixes: 11
