ADSL Router with the longest range
- ADSL Router with the longest range
06-09-2008 12:05 PM
Hi fellow members,
Can any body give me some advice on a new router please.
I have a BT Voyager 2110 at the moment, but the wireless range is not that good. I have my tabletop computer downstairs, and would like the signal to reach upstairs to my bedroom so i can update the firmware on my Sony PS3. I have recently bought a laptop that just manages to to hang on to the signal in my bedroom but it is not that strong.
The distance from my tabletop computer, to my bedroom is approx 80ft . I know i could go down the path of buying home plugs but i thought a new router could solve my problem. Thanks for any help.
8 REPLIES 8
Re: ADSL Router with the longest range
06-09-2008 6:56 PM
Get a high-gain antennae yo replace the little stick aerial on your router/PC.
Routers don't vary much in output power.
Alternatively you should move your PS3 before updating - a failure halfway through a firmware update is seriously bad news!
06-09-2008 8:40 PM
Even if you got a router with a bigger range then your PS3 / laptops signal going back might not be as strong so you could still have problems.
If you just want to update the firmware on your PS3 you can download it onto a memory card and update it that way.
If you want to do on-line gaming wireless can suck big time so you might be better off looking at getting power line adapters or running some long flat ethernet cable (which is what I have done)
07-09-2008 8:34 AM
Try looking at the Netgear Extended range http://www.netgear.co.uk/wireless_modem_router_dg834pn.php
they describe it :
6 internal antennas continually survey the environment to optimise coverage
Eliminates Dead-spots using Smart MIMO* technology
Maximises coverage by auto-adapting to avoid interference & physical barriers
Improves range & speed of existing wireless devices
they describe it :
07-09-2008 10:00 AM
No really no!!! I have that router, 834PN (now collecting dust as a back up), and using the ps3 wireless controllers (or just about any bluetooth device) knocks out the wireless signal.
I have a BT 2Wire 2700HGV now which you can flash with a different firmware (if you're feeling brave) to boost the power of the wireless signal. Can be picked up on ebay pretty cheap.
10-09-2008 8:09 PM
Thanks for every ones comments,
Most helpful, i think i may try to download the firmware on to a flash card as i dont play games on the net.
I will let you know how i get on thanks so much.
18-09-2008 1:40 PM
You could see about buying a Wireless n router; they have a greater signal strength than "normal" wireless g routers. I've got this one and it seems to do the job: http://www.ebuyer.com/product/132751
28-09-2008 6:55 PM
Bear in mind that in most cases you will only benefit from a Wireless-N router if you also buy Wireless-N adapters. I bought one myself and found it didn't make a blind bit of difference using standard adapters that were only compatible upto Wireless-G.
Another solution that may be worth looking at is something along these lines:
http://www.devolo.co.uk/uk_EN/produkte/dLAN/dlanwirelessext.html
28-09-2008 7:00 PM
Also bear in mind that Wireless N is still only a preliminary standard and one make dosnt necessarily link to another
