A single device gives rogue speed test result.
Mardler
Router: Billion 7800DXL
Devices:-
ipad Air, Samsung S7, Sony laptop W10, Vodafone Smart Ultra6.
Rogue device: Vodafone Smart Ultra6 (second one)
Speed test: Ookla.
All devices give results between 9 and 16mbps which itself is odd because I have never seen that low before but it is momentary. The rogue SU6 gives 0.9 to 2.3mbps with ping c.150 and jitter >2000 (other devices all very good). This phone has been rebooted and the app reinstalled.
It isn't hugely important but any thoughts would be interesting.
Mods: feel free to delete or move this as you wish.
3 REPLIES 3
Fixes: 1,482
Re: A single device gives rogue speed test result.
Moderators Note
This topic has been moved from ADSL Broadband to Tech Help
VileReynard
Fixes: 20
I expect you are just measuring wifi speeds - which are always variable.
Mardler
No, I definitely am not measuring different WiFi speeds.
I have several devices run tests in parallel and discretely. The result is always consistent: the one phone shows a a speed c.10% of everything else.
For example, I just ran a test. Second figure is this iPad:-
Ping: 140/43
D/l: 0.64mbps!/14.00
U/l: 0.94/1.00
There is something wrong with the SU6 but what?
