A quick question about powelink adapters
rogadodge
I have two powerlink adapters which work fine. Can I add another one to the same system, from another manufacturer? Are they interchangeable? Any ideas anyone, please?
6 REPLIES 6
PeterLoftus
Fixes: 5
Re: A quick question about powelink adapters
I've mixed products, speeds and manufacturers with no problems. The 200av and 500av work OK together but the older slower units don't.
Also I have four units all synchronised together
To do is to be - Neitzsche
To be is to do - Kant
do be do be do - Sinatra
chenks76
All Star
Fixes: 12
the only things you need to check is that they all use the same technology/protocol to create the network connection.
other than that it should be fine to use different manufacturers.
rogadodge
Thanks guys, I have gone ahead and ordered via Amazon. Not sure how to check technology/protocol, but they are both good makes (Edimax 500mbps & T P link 600mbps) so fingers crossed.
My other solution of using the Power line between the Bt box and the router, which was working fine decided to stop working.
ejs
Aspiring Hero
Fixes: 25
I'm not sure either of those could be considered good makes.
chenks76
All Star
Fixes: 12
Edimax and TP Link would be in the "reasonable" make IMO.
NorthPole
Fixes: 6
I've never had anything but excellent results from several bits of TP-Link kit - well made and good value in my opinion. Edimax I wouldn't be so sure of (is that the brand sold at Maplin?), but I have no personal experience.
