A ndroid - Deleting/uninstalling apps not required .
shutter
Fixes: 64
OK... so I know how to delete the "short cut" from the desktop... but how do I uninstall, no longer needed apps?  can`t find anything on the Apps screen (where they are all listed).. nor can I find them listed with the file manager ...
Undecided
3 REPLIES 3
DaveyH
Champion
Fixes: 12
Re: A ndroid - Deleting/uninstalling apps not required .
Settings > apps >  tap on the app you want to remove and you will see the uninstall option, or play store > my apps, and uninstall from there
shutter
Fixes: 64
OK... Got that... Thanks...  Wink
Fixes: 1,481
or if on a more recent version of android you can long press the app in the apps screen and that will give the option to delete it.
