A couple of techy problems
shutter
Fixes: 65
Following on from my sojurn withe Firefox updates on Mint 15... which eventually was resolved by Foxy suggesting a "get-apt" command... and also installing Mint 18.1 .
The laptop concerned, is a Dell Inspiron 2200, which, when originally brought to market had a 60G HDD, and less than 2 Mb of ram.  ! ! .. it also had WIndows XP on it.
Great grand daughter downloaded "something" and it "stopped working".. so I offered to "have a look at it".. and try to get it working again...   couldn`t find what was wrong with it, after trying many things.. so decided that I would try and see if I could get it to run VISTA ( which I still have the CD for,...  )  and proceeded to install it... it worked... to a point..
two things came to notice, ... firstly.... there seeme to be no "sound" output... the speaker icon on the bottom task bar, had a big red X over it.. and when hovering, it announced that there was no sound hardware .
So I went into the Diagnostics,... and sure enough, it passed the sound test !.. and I could hear sound from the speakers and from the phones. in "left" and "right" applications..   So I tried to play a music video... it started to play for about 5 seconds, and then disappeared.
ok.. now another problem arises.... WIFI... it was connected by the cable to the router...  so I try the wifi connection... it shows all the neighbours  SKY and VM signals..  but it doesn`t show my own router... which is about 3 feet away from the laptop...and the router is in communication with this laptop sitting alongside the Dell on the same desk !.
OK... so.. I dig out an old hdd, that I put Mint 15 on a couple of years ago... plug the hdd into the Dell 2200 and hey presto... Talk about plug and play ...  I never expected that... !  it booted up with no further effort...
I was now looking to see if the sound was working... and lo and behold... play a music video.. and we have sound in speakers and phones... !.. yet windows said there was no sound hardware ! ! !..
Wifi has always been a bit "iffy" on Linux, for me... as many know from previous threads.. so I was expecting trouble trying to get it to work on this old Dell.. and sure enough.. no matter what I tried, I could not get it to show any wifi activity at all...
After I had installed VISTA on the other HDD, .. and had the sound problem... I did download and install several drivers from the Dell Website... but that did not solve the sound problem..
I used NDISWRAPPER and B43-fwcutter on the Mint application..   ( I even changed the HDD and installed a new version of Mint 18.1 on it... to see if that would help.. but no..
So.. can anyone point me in the direction of...
A... solving the Vista sound problem
B.. . solving the Vista WIFI problem
C... solving the Mint 18.1 WIFI setup /connection
( yes I did make sure I checked that the wifi switch was on... ( toggled it a couple of times to  make sure )  ).
16 REPLIES 16
VileReynard
Fixes: 20
Re: A couple of techy problems
Surprised to see you used I used NDISWRAPPER and B43-fwcutter !!! - I've never tried ndiswrapper but I believe it's seriously hard work. Grin
You can identify your wifi chipset with the following command
lspci -nn | grep Network
I got
02:00.0 Network controller [0280]: Broadcom Corporation BCM4313 802.11bgn Wireless Network Adapter [14e4:4727] (rev 01)
The [14e4:4727] identifies the chipset and can be searched for on web sites...
But this shouldn't be necessary as Mint 18 has an option for this - it takes a couple of minutes to run.
Select Administrator -> Driver Manager and you should eventual get something like this:-Screenshot from 2017-05-02 17-06-35.png
shutter
Fixes: 65
@VileReynard  Thanks for that..Well, I say i "used" it... but in effect.. I was just following some on line suggestions as to what to do, and was trying anything that seemed like it may work..
As for the "Driver Manager"... I did manage to get that page up... but it did not show any wifi driver, as it did on earlier occasions.. it did show some obscure driver, that was not related to wifi...
At the moment,.... the laptop is languishing in a dark cupboard, and in disgrace with me...so it will stay there for a couple of days/weeks until I get terribly bored, and decide to have another go...
What I could not understand, was how the SOUND worked on Linux,... and Windows said there was no sound hardware...    also... could not understand why the WIFI found the neighbours wifi  ( about 6 of them ).from SKY and Virgin Media... but could not find/see/show mine...  in effect... ( apart from it being secured ).. I should have been able to connect to the neighbours in Windows... !     ( no not by looking through their windows ! ! )..
VileReynard
Fixes: 20
Do you have your wifi set to channel 13?
In some countries, such as USA, this doesn't exist; so a change to channel 12 might fix it.
See https://en.wikipedia.org/wiki/List_of_WLAN_channels#Interference_concerns
shutter
Fixes: 65
@VileReynard   No, I am on channel 12 at the moment.... ( and have been for a while.... ).. strangely, although it did not show my connection on the "networks are available" on Windows... the laptop has been registered by the router as being part of the "home network"..  !...
Incidentally,  I can`t find how to change the channel on my Thomson TGN582n router... although I have done it before....!
Browni
Aspiring Hero
Fixes: 60
In the USA channel 12 doesn't work either!
Coincidentally I was on the webpage @VileReynard mentioned earlier trying to figure out why my TV couldn't see the 5GHz channel my router was broadcasting on. (ch36 worked, ch100 didn't)
ReedRichards
Seasoned Pro
Fixes: 25
Wireless devices need to know that they are in the UK rather than the USA or they will ignore channels 12 & 13.  In Windows you can usually change the locale setting in Device Manager
Older computers have difficulty recognising what sound device they have and that makes it easy to install the wrong driver.  See if Linux will tell you what sound device it thinks you have then find the Windows driver for that device.
Vista has just 'expired' and was always prone to long irritating delays; it's cruel to land somebody with a Vista computer if it can be avoided.
shutter
Fixes: 65
@ReedRichards  Thanks for your input... not sure how to find out what sound device is on Linux... but would have thought that the Dell site, using the TAG number, would produce the correct driver. (I think there are three or four, depending on the device ).. If I downloaded and installed them all, the computer should pick the correct one. ? ? ?
As for the WIFI..   as mentioned... when it was first fired up, on the XP ... it appears that it registered with my router and is listed as part of my "home network"  on the router page.. but for some reason, although it sees the neighbours wifi`s.. it doesn`t see mine ! !
   . If it appeared on the router on XP, then one would assume that CH 12 is OK for it to work....  ( I never really tried it or considered it when I originally booted up to find out what was wrong with the computer).. (will check out the Device manager point about uk or usa..location )...
 Vista may well have "expired"... but as an OS  it still works...... VIsta was fine for me... and I never had any problems with it...  as she is only 10 years old,... anything that works will do.. and that`s not being cruel ! ! .. I could put Win 2000 on it  ! ! .. ( never had any problems with that either )... well except the usual update problems..
shutter
Fixes: 65
Regarding the Channel Change on the router.... have done that.... now on Ch 6 ( couple of other weak stations on there).. ready for the next session with the Old Laptop....
HairyMcbiker
All Star
Fixes: 21
Since it is a Dell, did you check the Dell web site for a LINUX wifi driver?
They are quite good at Linux drivers unlike some manufacturers.
As to Vi****a no idea, that was what made me move to Linux many years ago!
ReedRichards
Seasoned Pro
Fixes: 25
Microsoft broke every Vista computer I have seen about half way through last year.  They now use an entire processor core searching in vain for Windows Updates so the performance is degraded.  I don't know what happens with a new Vista install.  Vista also sometimes takes AN AGE to shut down which is massively annoying if you are trying to restart the computer as part of some service operation.  I have timed the wait as over 10 minutes on occasion.
You need to install the sound driver that matches your hardware and no other.  Often the same computer model can have a variety of different hardware configurations so this can be problematic.  Maybe one of the Linux fanboys can tell you what their equivalent of Device Manager in Windows is?
HairyMcbiker
All Star
Fixes: 21
In Mint, open the Menu, type in hard
you should see System Profiler in the list. Click on it. That will give you as much info as you want about your pc.
VileReynard
Fixes: 20
A useful Linux utility to install is inxi, to install
sudo apt-get install inxi
It has many options, but inxi -Axx should reveal things,
I get:-
Audio: Card-1 NVIDIA Device 0e0f driver: snd_hda_intel bus-ID: 01:00.1 chip-ID: 10de:0e0f
           Card-2 Advanced Micro Devices [AMD/ATI] SBx00 Azalia (Intel HDA)
           driver: snd_hda_intel bus-ID: 00:14.2 chip-ID: 1002:4383
           Sound: Advanced Linux Sound Architecture v: k3.16.0-4-amd64
shutter
Fixes: 65
Thanks for all the updates and advice, guys.... given me some impetus to get the thing out of the cupboard and give it another bashing....got nowt else to do today.. and it`s looking a bit grim outside !..
OK  just got it out of the cupboard... plugged it in...booted up... and... WIFI connected.... so it most probably was that Channel 12 that caused the problem there....
still showing a big x over the speaker... so am going to plug in the Linux hdd... and see how that performs..
shutter
Fixes: 65
@VileReynard & @ReedRichards  ok... Have installed the Mint 18 hdd... and done the sudo apt-get inxi..
inxi -Axx gives
Audio:      Card  Intel 82801FB/FBM/FR/FW/FRW (ICH6 Family) AC`97 Audio Controller
               Driver: snd_intel8x0 Ports: ed00 ec 40 bus-ID 00:1e.2  chip-ID 8086:266e
               Sound: Advanced Linux Sound Architecture v: k4.4.0.53 - generic
So it looks like window Vista is messing things up.saying there is no sound hardware.
running a music video on the Mint 18 ... using the default player.. no sound and video appears frozen.
however, if i "open with" and use VLC media player , the video is "jerky" and blocky . the audio is excellent quality though !...  so will download a new set of Dell Drivers...
