A&A VOIP hitch
redsox9
Fixes: 4
A&A VOIP hitch
Just joined A&A VOIP after upgrading to Plusnet FTTP. With the help of the guide notes from Tettin and Calmcurious I am setting up my Grandstream HT802 and my Panasonic DECT phones. I updated the ATA firmware to 1.0.59.3 and put in my A&A account details but I cannot make or receive calls. When I ring another number from the Panasonic I get an engaged tone and when I use my mobile to ring the Panasonic I also get an engaged tone. Any suggestions?
I have adjusted the expiry settings, set IP Protocol to IP4only and set the time zone to GMT. NAT transversal is set at keep alive.
6 REPLIES 6
Fixes: 581
Re: A&A VOIP hitch
Does the ht802 show registered ? and does it show as registered if you login to the A & A control panel ?
outcast
Aspiring Champion
Fixes: 19
Re: A&A VOIP hitch
@redsox9  do your settings look like these ? - https://support.aa.net.uk/VoIP_Phones_-_Grandstream_HT8xx
redsox9
Fixes: 4
Re: A&A VOIP hitch
@MisterW
Porting of my number from BT was completed four days ago and it's registered on the A&A control page. But the blue phone light on the Grandstream is off. It comes on only when I try to make a call. Should it always be on if my phone is registered? Both the power and Internet lights are always on.
@outcast
Thanks for that.
outcast
Aspiring Champion
Fixes: 19
Re: A&A VOIP hitch
@redsox9 wrote:
... the blue phone light on the Grandstream is off. It comes on only when I try to make a call. Should it always be on if my phone is registered? Both the power and Internet lights are always on.
@redsox9  it should look something like this -
Fixes: 581
Re: A&A VOIP hitch
@redsox9 have you created a voip password on your  A & A account ? see here https://support.aa.net.uk/VoIP_Password
IIRC initially it appears as though a password is there BUT you need to generate one before it will activate. You need to then change the authentication password details on the ht802 to the new one.
redsox9
Fixes: 4
Re: A&A VOIP hitch
@MisterW
Generating a new password to activate sorted it.
@outcast
The HT802 phone light is now solid blue and showing registered.
Many thanks to you both on a bright Sunday morning.
