A Forum down but downforeveryoneorjustme says "just me"
- Re: A Forum down but downforeveryoneorjustme says ...
29-03-2016 6:44 PM
There is a forum I frequent, that for several days I have been unable to connect to. This is the message which fills the page
My forum is one of many on f.u. and all I have looked at bear similar warningd, and so I am puzzled why I am told it is just me.
Please! Has anyone helpful suggestions? I've tried clearing the cache, and checking DNS settings.
Quote Warning: mysql_connect(): Too many connections in /var/www/html/forumup.co.uk/config/multiforums.functions.inc.php on line 65
5 REPLIES 5
Re: A Forum down but downforeveryoneorjustme says "just me"
29-03-2016 6:59 PM
the problem isn't with your connection but something at the hosts and their mysql instance.
29-03-2016 7:06 PM
Si downforeveryoneorjustme is duff then! Are there better similar sites, I hope?
29-03-2016 7:16 PM
it's working fine as the site returns a response, it can't tell you if the page it's displaying is any good or not. technically the site is up and displaying a page, it's a just a page saying it's broken
29-03-2016 7:22 PM
Quote from: Luzern1966 Si downforeveryoneorjustme is duff then! Are there better similar sites, I hope?
Try this one: http://www.isitdownrightnow.com/
29-03-2016 8:33 PM
I'll bookmark that one!
