64/32bit hardware
7up
Fixes: 17
64/32bit hardware
My desktop PC has a 64bit mobo running 64bit Win7.
I have a wireless card PCI that is 32bit.
Assuming that there is a PCI slot (not totally sure on that lol) will the two mix or do 63bit boards only accept 64bit cards?
Ta
5 REPLIES 5
rongtw
Fixes: 12
Re: 64/32bit hardware
From Mr Google Thumbs_Up
Most 32-bit PCI cards will function properly in 64-bit PCI-X slots, but the bus speed will be limited to the clock frequency of the slowest card,
https://en.wikipedia.org/wiki/PCI-X
mikelahey
Fixes: 12
I've never seen a 64 bit PCI slot on consumer grade hardware. Most are 32 bit, even on modern motherboards.
You can use a 32bit PCI card in a 64 bit PCI-X slot and vice Versa.
HairyMcbiker
All Star
Fixes: 21
Last time I saw a 64bit pci slot was on a Compaq server. Weird looking thing it was. I was fitting a 4 way gigabit nic into it. (that was over 10 years ago)
VileReynard
Fixes: 20
I once used a 64 bit SCSI card (in a 32 bit PCI slot).
Worked perfectly well.
rongtw
Fixes: 12
long time since i saw anything SCSI
