5ghz wireless failure??
- Re: 5ghz wireless failure??
17-06-2019 9:43 PM
22-06-2019 5:01 PM
This topic has been moved from My Router to Tech Help as it's not referring to a Plusnet router.
23-06-2019 11:11 AM
@penfold wrote:
... We've always had poor signal in the conservatory with 5ghz, even though it's only passing through 1 wall, but tonight I found that 5ghz was undetectable in the conservatory. ...
Maybe a silly question, but have you installed a WiFi Analyser on a phone so that you can move around your house and find the signal strength at various locations? Whilst not the be-all end-all of instrumentation it may solve the mystery of your disappearing 5Ghz signal.
The one I use on my Android phone is a free opensource download called, wait for it, WiFi Analyzer.
Happy hunting and good luck with it!
23-06-2019 12:39 PM
That's on my phone, but stupidly never thought to use it..... Will switch 5ghz back on and see. Oddly enough this happened after the smart hubs usual 14 day reboot..... Coincidental.......
23-06-2019 12:55 PM
Very variable signal on 5ghz, even in the same room its struggling at around -70. Upstairs signal wildly varying and sometimes undetectable even in the room directly over router. I suspect the 5ghz radio is failing, or is this a thing that can happen.
2.5ghz working fine.....
27-06-2019 12:18 PM - edited 27-06-2019 12:20 PM
@penfold wrote: Is it possible for just the 5ghz band to fail.
Like anything electronic it can fail. Over the years I've had a router and a WiFi dongle fall over. Always a good idea to have a cheap backup available, which is why I still have the router that PN supplied in its box. If my paid for router / modem goes wrong, I've got a known good to check to find out what is wrong. Before condemning anything always try it with some other signal. Got any neighbours that use 5Ghz? Does it pick theirs up...........
