550 Relay error with T-mobile
- Re: 550 Relay error with T-mobile
07-09-2007 12:18 AM
I get this error while trying to send emails through my co.uk account on my laptop using a t-mobile usb hdspa modem.
Everything works ok on my wireless connection at home, after a bit of investigation online I found that the error probably arrises because I am sending mail through a PN account but from a wireless mobile account. This I guess is to stop spamming or spoofing.
Do I need to change the SMTP settings for my email account or do I require some further settings from t-mobile?
Unfortunately T-mobile won't accept my details to log in to thier support forum even though the usb modem has a sim card and a number.
Any Help appreciated.
3 REPLIES 3
08-09-2007 3:20 PM
Thank you for your input.
Where do these settings go on the email account?
Quote Try smtp.t-email.co.uk
08-09-2007 3:56 PM
outgoing or SMTP server
08-09-2007 8:12 PM
Thank you m8, this is the answer.
I have set up two email accounts with the same settings other than the smtp relay, one called home and one away so that I can send email from either my lan or the usb modem.
Would have been nice to have just one account that could do either depending if there was a network connection but what the hey it works now anyway.
Thanks again Peter for saving me losing a weekend trawling through help files.
