500GB USB Drive format
- Re: 500GB USB Drive format
14-05-2014 9:42 PM
Windows 7 won't do it as it insists on NTFS.
I currently have it attached to a Linux Mint laptop and trying a FAT format.
The drive will be put into service as a PS3 backup destination.
Any suggestions please?
14-05-2014 9:44 PM
14-05-2014 9:54 PM
14-05-2014 10:05 PM
You can create 2 partitions on the usb hard drive. make the first 32 Gb and format to fat 32 and use the rest of the disk as another partition in ntfs
14-05-2014 11:58 PM
I'll see what tomorrow brings.
15-05-2014 6:52 AM
Quote from: Strat I have a 500GB USB hard drive I need to format FAT32.
# mkdosfs -F 32 -I /dev/sdX1
Where X is whatever your disk appears as (sdb, sdc, or whatever)
That's what I use for formatting USB sticks with FAT32
16-05-2014 6:39 AM
16-05-2014 12:20 PM
York.
20-05-2014 2:08 PM
I have successfully formatted the USB drive to FAT32.
The PS3 backup procedure starts and announces that it will take approximately 2 hours and 59 minutes.
It then fails with an error code which varies.
The current one is 80010006 (problem accessing a file).
I had another go with a better quality USB cable and received this error code...800283E1 which Sony have no search result for.
20-05-2014 3:05 PM
I dimly recall a backup issue long ago where removing the ethernet cable afforded a solution.....crazy.
2 hours 50 minutes to go....
