5.2 Ghz Antenna
30FTTC06
Fixes: 4
5.2 Ghz Antenna
Anybody know where I can get a 5.2 Ghz WiFi Antenna from in the UK. I've looked on RS etc and can't find any, why is this? I've seen a funky video of how to make one, but I would still have to buy gear or at least butcher a brand new 2.4 Ghz antenna.
I'll be using this on ch 36/40 5180 Mhz and 5200 Mhz
15 REPLIES 15
NorthPole
Fixes: 6
Re: 5.2 Ghz Antenna
A quick search on eBay came up with this dual-band antenna - I can't say whether or not it's any good though. There may well be others on offer - I searched for '5 Ghz antenna'.
30FTTC06
Fixes: 4
Re: 5.2 Ghz Antenna
I'm using a dual band antenna at the moment, but thanks very much for the link.
I want to use seperate antennas for my router but single band 5.2 Ghz to 5.8Ghz WiFi Aerials seem to be hard to come by.
NorthPole
Fixes: 6
Re: 5.2 Ghz Antenna
I suspect most router antennae are dual-band, as every 5 GHz router I am aware of also broadcasts on 2.4 GHz. You may find a specialised 5 Ghz antenna, but one with the correct type of fitting may be the problem - good luck anyway.
EDIT - how about this one?
ejs
Aspiring Hero
Fixes: 25
Re: 5.2 Ghz Antenna
I think routers often use internal antennae for one band and external for the other.
A client device may well use the same antennae for either band, but it will only be connecting to one band or the other, not both at once.
30FTTC06
Fixes: 4
Re: 5.2 Ghz Antenna
@NorthPole Superb, good find! I'll get this one
Specs
30FTTC06
Fixes: 4
Re: 5.2 Ghz Antenna
I do have another question though! will using these alter the frequency of the antenna/antennas ?
ejs
Aspiring Hero
Fixes: 25
Re: 5.2 Ghz Antenna
Are you planning to attach the 2.4GHz and the 5GHz antenna to the same connector?
What router do you have? You should really check if the external antennae are for one band, and internal antennae are used for the other.
30FTTC06
Fixes: 4
Re: 5.2 Ghz Antenna
@ejs Yes both.
I'm looking at this.
Strat
Fixes: 565
Re: 5.2 Ghz Antenna
Moderator's note by Dick (Strat) Fix moved to NorthPole at Ops request.
30FTTC06
Fixes: 4
Re: 5.2 Ghz Antenna
Same router as the Video above @ejs
ejs
Aspiring Hero
Fixes: 25
Re: 5.2 Ghz Antenna
I tend not to bother to watch stuff in video format which could easily have been expressed in a few words. So I guess I'll never know.
Lots of modern routers apparently do use external dual-band antennae, I was thinking of older ones with internal and external for different bands.
30FTTC06
Fixes: 4
Re: 5.2 Ghz Antenna
The Video says that a WDR3600 uses A dual band antenna which is kind of not the best thing, So at that the guy breaks out a drill and soldering iron and adds 2 new fly leads and sma sockets to the back of said WDR3600 router, attaches 2x 2,4 Ghz antennas and 2x 5 Ghz and proceeds to show  before and after tests which show a marked improvement on 5 ghz band and a small improvement on 2.4ghz band.
My question is, will using adapters to achieve the same thing cause the wave length of the antennas to be altered ?
I don't see why it should if the fly lead size the guy mentions as doesn't matter how long/short they are.
Hope that clears things up a tad for you.
Sorry expressing myself though the written word isn't one of my strong points.
NorthPole
Fixes: 6
Re: 5.2 Ghz Antenna
@30FTTC06 wrote:
I'll get this one
TBH, judging by the shape alone I would have said that was a 2.4GHz antenna - I used to have a virtually identical TP-Link one. But the Solwise spec. does say 5GHz .......
30FTTC06
Fixes: 4
Re: 5.2 Ghz Antenna
I made a choice lets see what happens! I'm still none the wiser if the taps will alter anything.
Waiting on ejs to return fire....
Edit: Bought these for the 2.4gig
