4oD and Vista
DavidButler
4oD and Vista
has any one experinced problems using 4oD andd Vista. I hav etrired to use but keep getting messgaes advising that the DRM needs updating or is corrupt. chanel 4 are not mush use in assisting they have said to follow the instruction on MS website but having down this i still get the same problems.
Interested to here from anyone who has has the same or similar problems and managed to rectify.
Dave
RobDickson
Re: 4oD and Vista
I had a similar problem when beta testing the BBC IPlayer. Perhaps the BBC's help pages might help:
How can I solve digital rights management problems?
DavidButler
Re: 4oD and Vista
Rob
Thanks for your reply, I have looked at the BBC help but still not able to reslove problem with 4oD. I have no issue with watching BBC iplayer.
Thanks again
aetos
Re: 4oD and Vista
BBC player works with vista, the last time I tried it, 4oD was still not vista compatable having a problem with flash player, it appears to fail the full install but will work with conflicts
Mark
