4chan blocked?
bobpullen
Fixes: 330
Re: 4chan blocked?
Quote from: jhoughton1234
Quote from: Chris
As has been mentioned it's most likely that the site has ended up on the IWF watch list (the traceroute earlier in the thread shows this too).
Out of interest, which entry in the traceroute shows this?
It's the tun0 entry:
6    33 ms    32 ms    33 ms  tun0.ptn-gw01.plus.net [212.159.2.101]
I'm having trouble with another site that seems a likely candidate to have ended up on the IWF list (they host user-uploaded content and aren't very reactive at removing it if people complain), and would like to be able to check if this is the actual cause.
What site?
If so, is there any way to disable the block?  It really *shouldn't* be operating on a per-domain basis when only a very small minority of pages on these sites are likely to be offending.
It's not supposed to. It's designed to work on a specific URL basis.
Anyway, we made some changes last night around 10.30pm so I'd be interested to know whether or not you're still having problems?
bobpullen
Fixes: 330
Re: 4chan blocked?
Update here.
