4OD - not working in Mint 15
ITWorks
Fixes: 8
Hi all
i can not get 4oD to work, had a quick Google seems like a few people have or had this problem.
it looks as though it will play the stream ( get the image in the background of the program) , then the white circle keeps on going round.
tried  GC,FF and Opera
any ideas?
Regards
Mike
4 REPLIES 4
Kelly
Fixes: 9
Re: 4OD - not working in Mint 15
I beleive they'd changed the encoding of the 4oD stream, which is why it no longer works on XBMC.  May be the same problem?
Kelly Dorset
Ex-Broadband Service Manager
ejs
Aspiring Hero
Fixes: 25
Does installing the incredibly obsolete hal fix it?
http://helpx.adobe.com/x-productkb/multi/flash-player-11-problems-playing.html
Waldo
I'd never used 4OD before, but trying it now (Arch Linux) hal is indeed the difference between it working and not working.
HairyMcbiker
All Star
Fixes: 21
Same issue in Mint 14, never used 4OD so never saw the problem before. Or used flash that much.
