4OD - not working in Mint 15
- Re: 4OD - not working in Mint 15
30-05-2013 6:24 PM
Hi all
i can not get 4oD to work, had a quick Google seems like a few people have or had this problem.
it looks as though it will play the stream ( get the image in the background of the program) , then the white circle keeps on going round.
tried GC,FF and Opera
any ideas?
Regards
Mike
any ideas?
Regards
Mike
4 REPLIES 4
30-05-2013 9:29 PM
I beleive they'd changed the encoding of the 4oD stream, which is why it no longer works on XBMC. May be the same problem?
Kelly Dorset
Ex-Broadband Service Manager
30-05-2013 10:19 PM
Does installing the incredibly obsolete hal fix it?
http://helpx.adobe.com/x-productkb/multi/flash-player-11-problems-playing.html
31-05-2013 6:44 AM
I'd never used 4OD before, but trying it now (Arch Linux) hal is indeed the difference between it working and not working.
31-05-2013 9:10 AM
Same issue in Mint 14, never used 4OD so never saw the problem before. Or used flash that much.
