4 Port USB hub query
shutter
Fixes: 65
Looking for a 4 Port USB hub....on ebay... and see some are USB 2.0 and some are USB3.0
what is the difference?  Want to use it on my laptop,(s) and possibly on my Android Tablet...
Is 3.0 preferable to 2.0..... ( because it is the latest version ? ? )  or what  ?
7 REPLIES 7
Oldjim
Resting Legend
Fixes: 63
Re: 4 Port USB hub query
3 is significantly faster if the device supports it
jelv
Fixes: 10
You'd also need a USB 3 port on the laptop or tablet to see any benefit.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
shutter
Fixes: 65
I would think my laptop(s) are USB 2.0  so getting a 3.0 would not be any different on the socket to a USB2.0 ...
There are different "designs" and some of the USB 3.0 seem to be more of what I am looking for...
Thanks guys  Wink
rongtw
Fixes: 12
USB3 is backward compatible with usb 2 .
hopefully if you get USB 3 now if you upgrade a new laptop its ok , if you get a usb 2 then later you may lose out on speed . thats all
shutter
Fixes: 65
ok thanks  Wink
picbits
Also USB hubs tend to be powered (with a few exceptions)
Make sure whichever hub you get that you get one that can be externally powered. A standard USB port can push out 0.5A (sometimes 1A) as standard which isn't enough to power some external peripherals.
twocvbloke
If your laptop has an ExpressCard slot on the side, you can buy a USB 3.0 ExpressCard to upgrade your laptop to USB 3.0, but again, you need USB 3.0 hardware to see th ebenefit, otherwise it's just USB 2.0 with blue sockets, and more expensive...
