32 & 64 ?
- 32 & 64 ?
32 & 64 ?
03-06-2012 4:16 PM
Windows 7 is available in 32 & 64 bit versions but I understand not as many peripheral devices work with the 64 bit version, does the same apply in Linux ?
Re: 32 & 64 ?
03-06-2012 4:51 PM
Re: 32 & 64 ?
03-06-2012 6:25 PM
Re: 32 & 64 ?
03-06-2012 9:49 PM
Re: 32 & 64 ?
06-06-2012 4:50 PM
Re: 32 & 64 ?
06-06-2012 5:55 PM
With the advent of ppa's and pretty good repositories there is less need these days to compile it unless you want to tweak it somehow.
Re: 32 & 64 ?
06-06-2012 6:55 PM
(Sorry, couldn't resist the temptation given the topic title )
Re: 32 & 64 ?
06-06-2012 10:30 PM
Once worked on a computer with a 16 byte (128 bit) virtual address space.
Only the first 48 bits was supported by hardware though.
Re: 32 & 64 ?
06-06-2012 10:59 PM
Quote from: jelv 96
32 + 64 would be 96 but 32 & 64 is actually 0
back on subject... I've been using various 64bit flavours of *nix for many years without any major problems... the occasional old bit of hardware may not have worked but generally 64bit driver support has been very good.
Re: 32 & 64 ?
07-06-2012 4:43 PM
This has been fixed for some time now though, so isn't a problem any more.
Re: 32 & 64 ?
24-06-2012 2:51 AM
karl.
