2704n firmware
penfold
Fixes: 5
2704n firmware
I have this router as part of my fibre upgrade but I don't use it anymore. I want to use it at another house but as a standard adsl router if that is possible. If  so does it need a firmware update and where can I get it from. Many thanks.
4 REPLIES 4
Mustrum
Fixes: 75
Re: 2704n firmware
It may depend on who the provider is at the other house, but you should not need any different firmware, just change the username and password.
penfold
Fixes: 5
Re: 2704n firmware
It's a plusnet account. Possible router issue, so need to try a replacement. Thanks for the info.
Anotherone
Champion
Fixes: 21
Re: 2704n firmware
Make sure the other user's username and password are entered before you connect it otherwise the ACS will set it up on your account.
I assume you've done a factory reset and set it up on ADSL. Check the MTU when you've connected, just in case it's not correct.
penfold
Fixes: 5
Re: 2704n firmware
Thanks for the advice anotherone. Its appreciated.  I hadnt done a factory reset, I was just going to enter the details and then connect up. Will reset it first.
