2704n firmware
- Re: 2704n firmware
2704n firmware
20-02-2016 4:06 PM
I have this router as part of my fibre upgrade but I don't use it anymore. I want to use it at another house but as a standard adsl router if that is possible. If so does it need a firmware update and where can I get it from. Many thanks.
4 REPLIES 4
Re: 2704n firmware
20-02-2016 5:38 PM
It may depend on who the provider is at the other house, but you should not need any different firmware, just change the username and password.
Re: 2704n firmware
20-02-2016 6:02 PM
It's a plusnet account. Possible router issue, so need to try a replacement. Thanks for the info.
Re: 2704n firmware
22-02-2016 1:29 AM
Make sure the other user's username and password are entered before you connect it otherwise the ACS will set it up on your account.
I assume you've done a factory reset and set it up on ADSL. Check the MTU when you've connected, just in case it's not correct.
Re: 2704n firmware
22-02-2016 9:51 PM
Thanks for the advice anotherone. Its appreciated. I hadnt done a factory reset, I was just going to enter the details and then connect up. Will reset it first.
