2704N dhcp reserved addresses
richardg8jvm
Hi
I'm going rapidly nuts since joining plusnet
I can with the expert menu set MAC address :IP Adress
yet it takes absolutly no notice
I've rebooted umpteen times now, and rebooted the devices
And its routing is abismal
device with a static ip , it will route to it , but it wont route return signals from WAN to it.
IP cam  I can connect to it while it has a static address,  but the IP cams mail client can send frames to the smtp server, but the replies from the server dont get routed to it.
put the IP cam  a dynamic address, and the stupid 2704N routes the replies from the smtp server OK
Then as it does not reserve the wanted address, you have to log in to the router to see whats attached to get the ip address of the device..
Is this normal behaviour of this device.
I CAN SEE  I'LL HAVE TO GET A DECENT ROUTER, ANY RECOMMEDATIONS Huh
TIA
Richard
6 REPLIES 6
VileReynard
Fixes: 20
Re: 2704N dhcp reserved addresses
All the routers I've had, allow you to reserve a chosen TCP/IP address with a MAC address.
No need for "expert" menus either.
Choose your router, then download the user manual before buying.
I generally get a Netgear router.
richardg8jvm
Hi
I went and got a Tp Link TD-W8968 , no problems with it , I did look at the user manual before as well.
Just a pity that PN supply something which is non RFC compliant.
aesmith
Fixes: 4
You can choose more options with the 2704N via the hidden "Expert" menus ... http://192.168.1.254/expert_user.html ; From memory that lets you set DHCP reservations, I'm pretty sure I had them set when I used a 2704N for a couple of weeks.
Anotherone
Champion
Fixes: 21
Quote from: vilefox
Please don't make misleading posts Jeremy, it's as aesmith has pointed out.
VileReynard
Fixes: 20
My point was that normal routers don't require "hidden menus" to do simple tasks.
Anotherone
Champion
Fixes: 21
It's not really "hidden", it's the expert user GUI, although you don't need to be much of an expert, it's so crippled Tongue
