2700HGV, some minor issues
penfold
Fixes: 5
Just got one of these to replace my old and trusty 585V6.  Unfortunately it came with the V6 firmware, which according to some forums, is not a good thing.... but never mind.....
Issues I have seen, are when I switch it on, it seems to take an absolute age, for the wireless to activate itself, I have on occasion had to diasable and re-enable to interface.  Once its on, it seems fine (I dont reboot the router every day).  Also, is it possible via the webpage, to manually resync or disconnect and reconnect the PPP session.  Can see any way at all of doing this.
4 REPLIES 4
bobpullen
Fixes: 316
Re: 2700HGV, some minor issues
Quote from: penfold
With mine (F/W version 5.29.107.19) I just browse to 192.168.1.254/MDC and then click 'Resets' under the 'Troubleshooting' menu on the left. On this page there's an option to reset the 'ISP Connection'.
There's loads of helpful info about these routers here.
penfold
Fixes: 5
Thanks Bob.  On the V6 firmware, that IP is not valid.  I Used the linky you posted to configure the router when I got it, but if I had looked further down, it describes how to reset PPP etc on V6 firmware Roll_eyes  Nothing on the wireless issues though...
Cheers
Chris
Fixes: 393
They do take quite a while to boot up. They run pretty cool ( unlike a lot of routers ) so best thing is not to turn it off. You can disable / enable the wireless without rebooting if you want to.
On the V6 firmware the 'Resets' link is available from the 'diagnostics' tab, they have removed the mdc link.
As its a V6 one, make sure the Openzone is disabled. Bob's link will explain all if you read it.
Edit : beat me to it...
penfold
Fixes: 5
Quote from: MisterW
Thanks Mr W.....  OpenZone was disabled when I first looked in the settings.  It has mysteriously enabled itself.  I have disabled again, but the forum Bob pointed to, that I have read extensively when I first got the router, says it can take up to 7 days to disable......  Wireless is fully protected however, with a WPA-PSK password, and Fusion disabled, and a lengthy router password now in there.  Seems like a good router so far....
