26" Monitor
Mav
Fixes: 515
26" Monitor
SWMBO wants her 24"monitor back as her PC is now working again.
I still require the use of two screens so want to get a new one but this time to match my Iiyama 26" 16:10 1920x1200.
I can find similar at 24", 27" and 28" but nothing at 26".
Has anyone seen anything that fits the bill?
Forum Moderator and Customer
10 REPLIES 10
rongtw
Fixes: 12
Re: 26" Monitor
26" is a odd size for some reason now  Huh
Mav
Fixes: 515
Re: 26" Monitor
So is 16:10!
The nearest I can find, so far is an Iiyama or a Dell. Both 24" 16:10.
Mayybe I'll just replace with another 24" 1920x1080 16:9 which can be got for a lot less.
Oldjim
Resting Legend
Fixes: 63
Re: 26" Monitor
Mav
Fixes: 515
Re: 26" Monitor
Thanks, Jim. Interesting but I am a bit weary of buying a reconditioned but I will look into the company selling it a little more.
Even though it only comes with a limited 30 day warranty it will still be covered by the SoG Act
VileReynard
Fixes: 20
Re: 26" Monitor
Why are virtually moderate -> large screens a fixed 1920 x 1080?
I'd expect a bigger screen to have more pixels...
picbits
Re: 26" Monitor
It is a standard resolution for watching 1080p HD content in. The panels are also used for HD televisions so need to display a native 1920x1080 for Full HD content.
Larger monitors do have higher numbers of pixels but tend to be much more expensive as they aren't as mass produced as the 1080p panels.
nanotm
Re: 26" Monitor
just grab a pair of smaller monitors for a cheap deal price, ebay often has loads on offer (some of them even work) although I have found web searches often yield brand new grade a products much cheaper from places like over stockers (but be warned they regularly list the same product at multiple prices)
Mav
Fixes: 515
Re: 26" Monitor
Since I last posted SWMBO sourced a monitor from elsewhere so I was able to keep her 24" Smiley
But now my 26" 16:10 1920x1200 monitor has given up the ghost. The display shows for about a second then goes black. It does the same whatever input is selected. I have rebooted the PC, removed/reinserted the cables and turned the monitor off/on all to no avail Sad
I have borrowed her replacement monitor which works well so it's not a PC or cable issue. Seems I have to get a new monitor but I still want the larger workspace that I got used to with the IIyama.
I've totally given up on the idea of a 16:10 ratio but 2560x1440 looks promising (my Radeon HD6700 can handle that) so have been looking at the following:
Benq GW2765HT
Acer CB270HU
Acer G277HU
I'm favouring the G277HU but wondering if anyone has any thoughts on these or other suggestions? My budget is around £300.
nanotm
Re: 26" Monitor
would it not be better to have both monitors identical in terms of screen resolution ?
and if so then that might change the options available.
re the now broken illyama monitor, when you say it flickers do you mean you can see the desktop for a few seconds but it fades out and becomes plain black or is it bright flash then total darkness when you switch on ?
I ask because it might be cheaper to replace the broken bit inside the monitor if you can narrow down what the problem is
Mav
Fixes: 515
Re: 26" Monitor
Quote from: nanotm
For my use I don't think that is necessary. It certainly wasn't a problem with one being 1920x1080 and the other 1920x1200.
Quote from: nanotm
The desktop shows for about 1 second, no flickering or fading, it then goes black. The monitor is around 7 years old..
