2 x 2704n Routers, can I use 1 to extend the wifi range?
- 2 x 2704n Routers, can I use 1 to extend the wifi ...
31-08-2015 9:15 AM
If possible I would like router 2 to connect via wifi to router 1 (fibre config) so we can connect to router 2 on devices closer to it.
Re: 2 x 2704n Routers, can I use 1 to extend the wifi range?
02-09-2015 9:22 AM
Then you can probably try the firmware on this post: https://community.plus.net/forum/index.php/topic,142874.0.html
but there is risk in changing firmwares....
02-09-2015 4:03 PM
I downloaded the firmware and installed it on the spare router. I can connect to 192.168.1.1 via lan, I clicked on Network/Wifi/Scan and connected to the other router.
Now what do I need to do so I can connect my laptop to the spare router I just updated via wifi to use the fibre connection from the main router?
Should I be able to see 2 wifi signals when I scan for wifi devices on my desktop or just 1?
adie:quote
02-09-2015 6:16 PM
but by what you just wrote... were you planning to use it as a wifi repeater. e.g. your secondary/spare router talks to your laptop & the other router by wifi only?
if thats so... I will need a little time to figure that out.
P.S. dont do a factory reset....
02-09-2015 6:48 PM
Which one of these pictures are you hoping for....
(repeater mode is really slow)
02-09-2015 7:04 PM
Its the first image, repeater mode. So I guess it will be no real advantage moving the second router closer to the laptop in repeater mode.
The problem we have is the main router is on the ground floor and when a few devices are connected there is some bottleneck somewhere even though the fibre is very fast. We get almost 75MB DL / 19MB UL when connected via lan.
02-09-2015 7:21 PM
to be honest, it might not help if you think there is a bottleneck in the wifi.
I've heard there is some new software (7.275.2_F2704N_Plusnet) I dont have this software, but if you do - you can try to turn 40Mhz in the wifi mode. You will need to get answers in other threads though.
However I'll respond probably tomorrow regarding the repeater mode (after a test). Because it cant hurt to try it.
02-09-2015 7:39 PM
02-09-2015 7:56 PM
But there is another catch. 300mbs will automaticly move down to 144mbs/54mbs in a wireless noisy residential area.
03-09-2015 11:23 AM
By the way, I have never connected above 54mbps in my house. Then remove a third off that (overheads, errors & collisions). So my best thoughput speed is ~35mbps.
03-09-2015 1:24 PM
I might just grab a couple of powerline adapters instead then get the full speed upstairs hopefully.
03-09-2015 2:02 PM
good luck with lan power adapters
