2 line Phone
netreg
2 line Phone
Hi all,
I have a BT converse 2025 phone which allows me to plug two phone lines in (i work from home so i have home and office lines), but it seems to be dying on me, and now it looks as though BT dont do that nor any other phone that accepts two lines.  All the sites i have found are out of stock on the 2025.
anyone else out there know of a phone similar...
I have google'd but cant find anything Sad
thanks in advance
minkey
Re: 2 line Phone
This website has a search facility for multi-line phones. A lot of them are voip / dect but some look like they would fit the bill
http://www.home-phones.co.uk/search/phone-wizard/
HTH
Jeff
netreg
Re: 2 line Phone
Cool,  thanks, will check it out
