2 line Phone
- Re: 2 line Phone
2 line Phone
15-04-2008 4:52 PM
Hi all,
I have a BT converse 2025 phone which allows me to plug two phone lines in (i work from home so i have home and office lines), but it seems to be dying on me, and now it looks as though BT dont do that nor any other phone that accepts two lines. All the sites i have found are out of stock on the 2025.
anyone else out there know of a phone similar...
I have google'd but cant find anything
thanks in advance
thanks in advance
2 REPLIES 2
Re: 2 line Phone
15-04-2008 6:04 PM
This website has a search facility for multi-line phones. A lot of them are voip / dect but some look like they would fit the bill
http://www.home-phones.co.uk/search/phone-wizard/
HTH
Jeff
HTH
Jeff
Re: 2 line Phone
15-04-2008 8:00 PM
Cool, thanks, will check it out
