10 million bicycles in beijing
- 10 million bicycles in beijing
03-11-2009 12:48 PM
chucked the china block list on to peer block last night and cant belive how many connections from china they are.
now just need a list for trash talking yanks
2 REPLIES 2
Re: 10 million bicycles in beijing
03-11-2009 1:58 PM
I`m a bit "thick" about this......
what is it?
what does it mean?
where did you find it?
should I be worried about it?
is it happening to me? etc.....
what is it?
what does it mean?
03-11-2009 2:04 PM
http://www.peerblock.com/
peer block (replacment for peer gurdian) is just a program you add lists to that block certain ip ranges for diffrent reasons ie knowen hackers and the whole of china's ip range .
nope nothing to worrie about all those attempted connections from china are why am seeding stuff on utorrent hence why there is so many connections.
you can all so use the ad blocker list which i find useful clearing up all that unwanted garbage on webpages all thoe FF has a nice add on for that any way
extra lists found here http://www.iblocklist.com/lists.php
